  3. Does allegro free physical viewer support skill?
  • Replies 8
  • Views 23136
stillfish
stillfish over 15 years ago
Hi all,
I wonder if allegro free viewer support skill language.
If it does support, is there there any difference or risk ?
I meant if any axl function would be locked or something?
  • DE202408202727
    DE202408202727 over 15 years ago
    No the free viewer doesn't support Skill. The licensed Physical Viewer does support Skill.
  • stillfish
    Hi Dave,
      When I test under physical viewer , it cannot open a new skill window by select "telskill" in Setup -> User Preference.
      And also I cannot type "skill" in allegro command window to enter "Skill>" from "Command>", it will shows "E- Command not found: skill."
      I think it is really really not frendly for skill developer in physical viewer.
      But, when i have loaded my skill file in "allegro.ilinit",  I still can call these functions under "Command>" of physical viewer if my functions were registered to command by axlCmdRegister().
      It confused me if i could release my skill function to people who have only Allegro Physical Viewer (licensed).
  • DE202408202727
    Hi, You are correct. There is no interactive Skill available in the physical viewer but it will work via the command window. You can also edit the menus and add your own custom menu commands there. There should be no problems distributing Skill to Viewer users. Just use the allegro.ilinit file and custom menus. Regards, Dave
  • Aneeba
    Aneeba over 5 years ago in reply to DE202408202727
    Hi Dave. I am trying to load a skill file ( with .il extension) but it doesnt work. I have updated the menu file and my sccript name is showinf there. But my question is how do I use the  allegro.ilinit file?
  • Aneeba
    Aneeba over 5 years ago in reply to stillfish
    Can you guide me how do I USE illinit file?
