  3. Pin / Via Property Locator / Report
  • Subscribers 160
  • Views 16553
eddieb1
eddieb1 over 11 years ago
Hello Experts,
Just wanting to know if there's a way to find a pin / via on a board design where a specific property is attached to it? Then once found create a report where the the Pin_name and net name is listed along with its x-y locations (i.e. XY coordinates)? The x-y coordinates must be active such that when you click on them it will take you the exact location of the pin/via.
Also the pin / via property I have in mind is the No_Shape_Connect Property.
How do you go about this?
Thank you in advance.
Eddie.
  • eDave
    eDave over 11 years ago
    defun( DE_findPinsWithProperty (@optional (prop "NO_SHAPE_CONNECT"))
    let((pins, p)
    axlSetFindFilter(?enabled '("NOALL", "PINS"), ?onButtons "PINS")
    axlAddSelectAll()
    pins = setof(pin, axlGetSelSet(), get(pin ->prop, prop))
    axlClearSelSet()
    p = axlDMOpenLog("propPins")
    unless(pins, fprintf(p, "No pins found\n"))
    foreach(pin, pins, fprintf(p, "Pin Name: %s, Net: %s, Location: %L\n", pin ->name, pin ->net ->name, pin ->xy))
    axlDMClose(p)
    axlUIViewFileCreate("propPins.log" sprintf(nil, "Pins with property: '%s'", prop), t)
  • eddieb1
    Thanks a lot Dave. Ill give a run.
  • eddieb1
    Works like charm Dave!!! Thanks again.
  • eddieb1
    Hi Dave, one request - can you please add a code that will highlight the pin/via when you pick the x-y coordinates? Thanks again Dave.
  • eDave
    Hi Eddie, that's much more complex code and requires a form to trigger the highlights. An easier alternative might be to highlight all pins with the property before firing up the log file.
