  3. delete the visible xsection layer
  • Subscribers 18
  • Views 9774
tennywhy
tennywhy over 7 years ago
i need a function, it get a number from user , if the number small than the currently xsectin layer number, then it will delete the visible layer pair( one conductor layer and a dielectrinic layer) , but i stuck at i verify a xsection layer are conductor and is visible currently ? im tried as follow ,but it doesnt work. so what's the right way ?
        xslayer = axlXSectionGet( nil 'all )
 foreach( xsNum xslyaer
                 if( xsNum->isEtch && secNum->visible then   ; or xsNum->CONDUCTOR i want verify the layer is conductor and visible
                        printf( "will delete layer pair %" xsNum->position )
                        axlDeleteByLayer(xsNum->position + 1 )  ;delete dielectronic first
                        axlDeleteByLayer(xsNum->position )     ;then conductor
               ) ; just the position attribute is worked
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    I think you need to be using axlXSectionDelete() instead of axlDeleteByLayer(), since axlDeleteByLayer() requires a layer name, not a position number
  • tennywhy
    tennywhy over 7 years ago in reply to DavidJHutchins
    thanks sir, i tried the axlDeleteByLayer, it's seem as the position and number could be work.  but i confused are how can check one layer if visible and is a conductor layer.
  • tennywhy
  • DavidJHutchins
    DavidJHutchins over 7 years ago in reply to tennywhy
    Something like the following might work:
    when(secNum == xsNum->position
        axlMsgPut("found %d - %s" secNum strcat(axlMapClassName("ETCH") "/" xsNum->name))
        when(xsNum->conductor && axlIsVisibleLayer(strcat(axlMapClassName("ETCH") "/" xsNum->name))
            printf( "will delete layer pair %d" xsNum->position)
            axlDeleteByLayer(strcat(axlMapClassName("ETCH") "/" xsNum->name) 'fixed)
            axlXSectionDelete(xsNum->position + 1)
            axlXSectionDelete(xsNum->position)
