  3. "Can't find window; cvf.dialog" error in Allegro 17.2
  • Subscribers 18
  • Views 2425
dontpanic
dontpanic over 7 years ago
Hi! In Allegro 16.6 I had aliases for layer display filtering, which would call functions like the one attached at the end of this post.
I just switched to 17.2 and when I try to execute the alias I get the following error in the Skill console: "E- Can't find window; cvf.dialog"
How can I solve this error and get back my script working?
Thanks, Jorge.
# displaylayer_top.scr
# Note: mapped to keyboard as:
# alias F4     replay displaylayer_top
setwindow pcb
trapsize 45
generaledit
color192
setwindow cvf.dialog
cvf layer_mode
setwindow pcb
generaledit
cvf global_invisible
cvf layer_tree_item 'Stack-Up'
cvf layers_visible stack-up stack-up/top TRUE
cvf layers_visible stack-up stack-up/soldermask_top TRUE
cvf layers_visible stack-up drc/package_top TRUE
cvf layers_visible stack-up drc/top TRUE
  • oldmouldy
    oldmouldy over 7 years ago
    You will need to record the script again since 17.2 no longer uses the cvf dialog, which is why it cannot be found when you replay the script.
  • oldmouldy
  • dontpanic
    dontpanic over 7 years ago in reply to oldmouldy
    OK, thanks for the info!  I'll try to re-create the scripts (I didn't record the original ones) and post the solution, for the record.
