  3. Problem with ARTWORK_PREFIX variable when using axlRunBatchDBProgram...
  • Subscribers 19
  • Views 1446
Problem with ARTWORK_PREFIX variable when using axlRunBatchDBProgram(artwork...
olov
olov over 6 years ago
I have a strange bahaviour when I use axlRunBatchDBProgram("artwork"....
To make sure I get the correct output names I try to remove ARTWORK_PREFIX and ARTWORK_SUFFIX variables before running the batch command, see code below. The problem is that if I have a design that have a prefix stored when I open the design, then this prefix is still included in the output name when I run the batch command. HOWEVER - if I check the prefix in the graphical environment (menu Export->Gerber Parameters) the prefix is empty after running the script. Also - if i generate the corresponding output from the graphical environment there is no prefix attached to the name.
If I then run the script again the prefix is still attached to the output name!
Is there some other variable that is used when running the batch command or what is the deal?
code for artwork generation:
axlDBDeleteProp( nil "ARTWORK_PREFIX")
    axlDBDeleteProp( nil "ARTWORK_SUFFIX")
    filmlayers = axlGetParam("artwork")->groupMembers                                                            ;Create list with the output films
    foreach(s_film filmlayers  axlRunBatchDBProgram("artwork" strcat("artwork -f " s_film " " axlCurrentDesign(), ".brd"), ?noUnload t ?logfile  "photoplot.log" , ?warnProgram t) system( strcat( "move .\\Output\\" s_film ".art " s_rel_outdir "\\" s_filename "_" s_film ".art")))
Olov
  • eDave
    eDave over 6 years ago
    You would need to save the design before running axlRunBatchDBProgram for that to work. Why not just run axlFilmCreate?
  • olov
    olov over 6 years ago in reply to eDave
    Is not axlFilmCreate just to create the films? In this case I want to generate the gerber files.
    Anyway - it now works after saving the design.
    Thanks!
  • olov
    Thanks!
