  3. Xnet issue in orcad pcb designer 17.2
  • Subscribers 160
  • Views 24849
GK MN
GK MN over 5 years ago
Hello ,
I am facing a serious issue with x net .
I have not set any SI model for x-nets but its showing random group of xnets , how to remove this ?
some of the power nets gets merged with signal net and showing as xnet , its not taking the constraint set for signal . I tried different method but unable to solve
I am not sure whether its imported from schematic library or not !
Please refer attachment .
I use
Girish
  • steve
    steve over 5 years ago
    You have ore than likely used Constraint Manager linked to OrCAD Capture so xnets are made by default. You need to add a property to the Comps level of the discrete parts connected to these nets called NO_XNET_CONNECTION with a value of True. This can be added in the PCB or the schematic.
  • GK MN
    GK MN over 5 years ago in reply to steve
    Thanks for your reply  , its really helped me a lot :) , I selected all the part on PCB and added  this property  .
    If i want o have xnet for few components '  I should  remove No_Xnet property for that particular set of parts and create model right ?
    Thanks once again
    Girish
  • CSCNalu
    CSCNalu over 5 years ago in reply to steve
    Hi
    I suspect this might be what my issue is but what's the comps level of the discrete parts?  I am in object properties of my schematic and under the "Parts" tab I don't see anything related to comps.
  • steve
    steve over 5 years ago in reply to CSCNalu
    So the Comps level is on PCB only. For schematic just add a new property to the Schematic Part called NO_XNET_CONNECTION with a value of True.
  • CSCNalu
    Ah that makes more sense - worked perfectly; thanks!
