  3. Shape to Route Keep Out Spacing - Automatic shape update...
  • Subscribers 160
  • Views 2554
Shape to Route Keep Out Spacing - Automatic shape update fails
Fredda
Fredda over 5 years ago
The highlighted 0V-shape in the figure below fails to update itself. It rounds the corner so that the shape creeps in to the Route Keep Out area of the component.
When manually updating the shape it successfully clears the Keep Out area, but as soon as I edit the design at another place, which updates the shape I get the above behavior.
I'm using Allegro 17.2-2016 S059 [9/10/2019] Windows SPB 64-bit Edition.
/F
  • steve
    steve over 5 years ago
    Check under Shape - Global Dynamic Params that Dynamic Fill is set to Smooth which may help. I would also get up to date to the latest hotfix S066 when you get chance.
  • Fredda
    Thanks. It is set to Smooth. And yes, I will update to latest version! Maybe its not a problem, but it feels safer to update when I have completed this layout and before I start with the next one...
