  3. change footprint without orcad capture schematic
  • Subscribers 161
  • Views 13064
ichliebedich
ichliebedich over 4 years ago
Hi all,
I need to change the footprint without orcad schematic.
for instance, there is a smd type usb footprint, I want to change this part to 5 pin header which mean same number of pins and nets
like this
regards.
  • avant
    avant over 4 years ago
    You can export the netlist and edit the netlist to change to the footprint name. Then import the revised netlist.
    You will need to export library files before importing netlist.
  • CadAce2K
    CadAce2K over 4 years ago
    Edit the pstchip.dat netlist file ; find the JEDEC_TYPE definition for the surface mount USB connector ; change that to the 5-pin header footprint name ; re-load the netlist (import logic). This will work as long as the 2 thru-hole pins are not numbered, as well as the outer 4 smd pins are not connections. If the 4 outer pads are for GND connections, this won't work, sorry.
  • ichliebedich
    ichliebedich over 4 years ago in reply to CadAce2K
    there was no pstchip.dat file if I export the netlist file from allegro PCB,
    I exported from the Allegro PCB with this option below
    which file do I need to edit and which variable do I need to edit?
  • CadAce2K
    CadAce2K over 4 years ago in reply to ichliebedich
    There is another way to do it, completely within Allegro (BUT!!! the footprints have to have the same pincount, electrical pin count)
    - First place the new footprint in your design (PLACE/Manual)
    - Swap the 2 devices (Place/Swap/Components)
    - Unplace the old footprint
    - Using LOGIC/Part Logic you can assign the RefDes to the new footprint. You may have to play with the part logic table to get it to work, but it should swap to the new footprint.
    Again, the footprints have to have the same electrical pinout defined.
