  3. Fab drawing size issue
  • Subscribers 160
  • Views 11909
HotrodJEB
HotrodJEB over 4 years ago
I am trying to create a fab drawing. I chose "ASIZEH" as a starting point. As you can see below, the drawing is too small and looks cluttered. If I try "BSIZE" it won't allow me to place it.
Board size is 6"x4".
Is the canvas size too small or an extents issue?
  • excellon1
    excellon1 over 4 years ago
    Ideally you are better off having a design size that is bigger than a sheet size. If a sheet is bigger than the design area then you wou't be able to place that sheet.
    It is easy to fix the design extents size. Here is a pic showing something suitable for a B-Size drawing. I find it better to go larger on the design so that I can zoom
    out past the actual sheet size.
    Try change your settings to what is in the pic and see if that works for you
    All the best.
  • HotrodJEB
    HotrodJEB over 4 years ago in reply to excellon1
    Your suggestion corrected the issue.
    Thanks for taking the time to answer with great detail.
