  3. Via Arrays
  • Subscribers 161
  • Views 12334
Via Arrays
PCBTech
PCBTech over 3 years ago
Using Via Arrays in your design provides the following advantages:
  • Mitigates Electromagnetic Interference (EMI)
  • Controls Crosstalk
  • Suppresses Resonance
  • Improves Power Integrity
Types of Arrays in Allegro PCB Designer
Boundary Arrays
  • Single-Sided – Adds an array along one side of one or more selected objects
  • Both Sides – Adds an array on both sides of one or more selected objects
  • Centered – Adds an array centered on one or more selected objects
  • Between – Adds an array between all selected objects that are parallel to each other
  • Surrounding – Adds an array surrounding the selected objects
  • Radial – Adds a circular pattern of vias or structures around one or more selected objects
Matrix Arrays
  • Across Board – A matrix of vias or structures is added filling the board outline
  • Across Shape – Matrices are added filling one or more selected shapes
  • Across Windowed Area – A matrix of vias or structures is added to a windowed area
Refer to the video for using Via Arrays in your PCB designs using Allegro PCB Designer.
Team PCBTech
Cadence Design Systems
  • Andrew018
    Andrew018 over 2 years ago
    Certainly, the information provided by Team PCBTech from Cadence Design Systems highlights the advantages of using Via Arrays in PCB design. It's a valuable resource for PCB designers looking to enhance their designs and address common challenges like EMI and crosstalk. The inclusion of different types of arrays, such as Boundary and Matrix Arrays, adds versatility to the design process, making it a valuable reference for both beginners and experienced designers.
  • zpofrp
    zpofrp over 1 year ago
    Is the radial type only support integer angle?
  • mahimag
    mahimag over 1 year ago in reply to zpofrp
    Hello zpofrp, currently radial type only support integer angle.
