  3. Allegro - Tip of the Week: Copy Shape to Different Laye...
  • Subscribers 160
  • Views 5481
Allegro - Tip of the Week: Copy Shape to Different Layers
PCBTech
PCBTech over 3 years ago
By now, many of you have used the Z-Copy command to copy shapes across layers. Consider a more robust option that involves first selecting a shape (Shape > Select Shape or Void/Cavity) and then using the right mouse button to access the Copy to Layers command. Select the target class and subclasses and then consider the options at the bottom of the form: Create dynamic shape and Retain net. Do not forget to click the Copy button before clicking OK. It can be an oversight sometimes.
Team PCBTech
Cadence Design Systems
  • soll
    soll over 3 years ago
    Hello, thank you for the tip ! May I ask why it is considered a more "robust" method for copying shapes across layer ? I don't see the difference. Is there a reliability issue with the Z copy method, or is it just more convenient to use the right click method ?
  • PCBTech
    PCBTech over 3 years ago in reply to soll
    Hello, there are no issues with Z Copy, it's just that having control in right mouse button is sometimes more handy while working.
  • soll
    soll over 3 years ago in reply to PCBTech
    Ok, thank you for the answer ! It is indeed more handy.
  • jes
    jes over 3 years ago
    thanks
