  3. Skill method to optimize netlist (pin assignments) during...
  • Subscribers 20
  • Views 2721
Skill method to optimize netlist (pin assignments) during routing using Allegro/Orcad.
Robert Finley
Robert Finley over 4 years ago
I requested that Cadence remove the previous share of this after I found out Microsoft Skydrive eventually stops working without my login.  By then, the post was locked.  Sorry about that.
Moved to GitHub.  https://github.com/RobertFinleyPublic/AllegroNetlistSwap_SKILL
Readme:  https://github.com/RobertFinleyPublic/AllegroNetlistSwap_SKILL/blob/main/README.md
  • Copy the skill script "swapback.il" to your %HOME%/pcbenv directory.
  • In the Allegro command windows, type "skill load swapback.il". Allegro should respond with a "t".
  • Type "swapback" to launch the script. A dialog window should appear.
To read the annotation update script to update your schematic (overwrite TEMP aliases),
