  3. DRC error & Constraint manager / Spacing
  • State Verified Answer
  • Subscribers 159
  • Views 3963
Manfred1
Manfred1 over 3 years ago
Hi!
In my layout are a few shapes. Concerning the voltage, 0.25mm spacing is sensitive. I get several DRC errors like this one:
LISTING: 1 element(s)
           < DRC ERROR >
  Class:           DRC ERROR CLASS
  Subclass:        TOP
  Origin xy:       (82.96 10.66)
  Constraint:      Shape to Shape Spacing
  Constraint Set:  DEFAULT
  Constraint Type: NET SPACING CONSTRAINTS
  Constraint value: 0.51 MM
  Actual value:     0.25 MM
  Element type:    SHAPE
  Class:           ETCH
  Subclass:        TOP
  Part of net name: N18349469
  Element type:    SHAPE
  Class:           ETCH
  Subclass:        TOP
  Part of net name: N18335736
I could not find the place, where the actual value of 0.51mm is stored. (Even after watching Module 09 of Allegro PCB Editor Basic Techniques v17.4-2019QIR4.)
I opened Setup / Constraints / Spacing... and typed in 0.25 at Spacing / Spacing Contraint Set / All Layers in column SCS and Row Shape To. After that, all the layers seem flooded with their main colour, no more black inside the outline.
This is because the shapes' dynamic fill is reset and needs update. This can be done via DRC / Display Status / Update all for example.
Unfortunately, this change is one more thing, where Undo is not possible.
Where can I correct the wrong shape-to-shape constraint value of 0.51mm?
Kind regards, Manfred
  • DavidJHutchins
    +1 DavidJHutchins over 3 years ago
    In the Constraint Manager, you need to find the SHAPE_TO_SHAPE_SPACING entries as shown in the image below:
  • Manfred1
    0 Manfred1 over 3 years ago in reply to DavidJHutchins
    Thank you for your answer. I typed in the desired value and it works.
    To remove the value, one must expand the columns by clicking on the field with the small triangle in the upper row.
