  3. PCB SKILL Update Text Using Comment
  • State Verified Answer
  • Subscribers 22
  • Views 7515
ryamashita
ryamashita over 3 years ago
I have a bunch of version numbers in my PCB database.  I have added a comment property to the version number TEXT in the database.  What I would like to do is use SKILL to go through all of the text on the board and look for the right comment property and when I find the comment property that was added to the version number, replace the TEXT value.  I have the code to be able to search through all of the text in the database but what I don't have is a way to read the comment property that is attached to the text.  Does anyone know if this is possible and what command to use to check if there is a comment attached to text and to check the value of the comment?  Below is basically what I am trying to do
procedure( ReplaceRevisionNum()
     axlClearSelSet() ; unselects all currently selected objects
     axlSetFindFilter(?enabled list("noall", "text", "noinvisible"), ?onButtons list("noall", "text")) ; sets the find filter to all visible text
     axlAddSelectAll() ; find all of the visible text
     selSet = axlGetSelSet() ; selects all visible text and stores a list of DBID to variable selSet
     foreach( selection selSet ; itterate over all of the DBID in selSet
          ;THIS IS THE CODE I NEED
          ;CHECK IF TEXT HAS A COMMENT PROPERTY AND IF VALUE OF COMMENT IS "REVISION" THEN UPDATE TEXT
  • eDave
    +1 eDave over 3 years ago
        when(selection ->prop ->COMMENT == "REVISION"
          axlDBAddProp(selection, '("COMMENT", "my comment"))
          axlDBRefreshId(selection)
    • Vote Up +2 Vote Down
  • ryamashita
    0 ryamashita over 3 years ago in reply to eDave
    Thank you dDave!  This code doesn't do exactly what I wanted but it did have the part that I was stuck on which was finding the text with a given comment property.  I just have to change axIDBAddProp line to axDBChangeText because I want to change the actual text and not the comment.
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago
    when(selection->prop->COMMENT == "REVISION"
             ; update text
  • ryamashita
    0 ryamashita over 3 years ago in reply to DavidJHutchins
    I am just curious as a hardware guy who doesn't know how to write code very well, what is the difference between if and when?  Why would you use "when" and when would you use "if"?
  • eDave
    0 eDave over 3 years ago in reply to ryamashita
    "If" can have an "else". "when" and "unless" can't. They just make the code easier to read.
