  3. importing Netlist to allegro
  • Subscribers 161
  • Views 10932
xiaoyi
xiaoyi over 3 years ago
Hi
There are errors when I import Netlist to allegro. The software version is 17.2.
ERROR: Schematic supports creating XNets for passive devices and for devices having XNET_PINS properties but the Layout will create XNets only for devices having XNET_PINS properties. Change setting in Layout or Schematic, re-generate files, and re-run the flow.
ERROR: Can't import electrical constraint data (pstcmdb.dat)
The Constraint Difference Report is shown in the figure below.
I don't know how to solve the problem.
Regards
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago
    You may want to read the documentation for 'netrev' in $CDSROOT/share/pcb/batchhelp/netrev.txt
    Then try running netrev from a command line using the -o option with either the -1 or -2 additional option flags
  • xiaoyi
    0 xiaoyi over 3 years ago in reply to DavidJHutchins
    thank you for your replay. I find this file.If i use command line, the Constraint Difference Report may not be made.but error is that Schematic supports creating XNets for passive devices and for devices having XNET_PINS properties but the Layout will create XNets only for devices having XNET_PINS properties. Change setting in Layout or Schematic, re-generate files, and re-run the flow.
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago in reply to xiaoyi
    Open the .cpm file in notepad & add the below lines & then generate netlist. When imported there shouldn't be any issue.
    START_CONSTRAINT_MGR
    AUTO_XNETS_USING_DML ‘OFF’
    AUTO_XNETS_USING_GATES ‘OFF’
    END_CONSTRAINT_MGR
  • andycolorful
    0 andycolorful over 2 years ago in reply to Schulz Jordan
    @Schulz Jordan
    I have added the macro command in the CPM file, but the same error happened.
    this error happened when I Iset the pin pair constraints in the constraint manager. but the pin pair setting can not be saved in the constraint manager.
