  3. use pin_delay property for selected net class / match g...
  • Subscribers 159
  • Views 6988
use pin_delay property for selected net class / match group
ujdaz
ujdaz over 2 years ago
I have pin_delay property assigned to the whole component (every pin of the FPGA has its own delay value assigned in the schematic library), and I am struggling with some DRCs on the PCB as for this specific design, I only need pin delay values considered for the DDR memory. If I click use pin delays in constraint manager, it calculates relative propagation delays for every signal causing DRCs for other signals, and here comes the question: is there any chance I can use pin delays in the PCB designer for specific nets / net classes without the library component modification?
BR
  • JuanCR
    0 JuanCR over 2 years ago
    Waiving the DRC is not an option?
