  3. saving in a previous version
  • State Suggested Answer
  • Answers 1
  • Subscribers 161
  • Views 10809
carl carley
carl carley over 2 years ago
we are running version v17.2 and have modified a customers design which was in v16.6. as 17.2 is not backward compatible is it straight forward to export a placement & routing file from the 17.2 pcb to be imported into the 16.6 version?
Delete all the routing etc and use the 2 files and regenerate the pcb data in the 16.6 version
i know exactly how to do this in other pcb tools but i'm new to allegro!
regards
carl
  • JuanCR
    0 JuanCR over 2 years ago
    Files such as .brd, .mcm, .sip, .dra, and .pad, which are saved in version 17.2, cannot be opened or downrev’d to 16.x. The recommended practice is to maintain both 16.6 and 17.2 databases/libraries.
    If you try to downrev any of the above files from version 17.2 using File — Export — Downrev design, the tool will display the following message:
    Padstacks (.pad) and symbols (.psm, .bsm, .fsm, .ssm) created in 16.x will load into 17.2 databases.
  • tennywhy
    0 tennywhy over 2 years ago
    now you can search x_downrev17.il ,and load it as loadi("x_downrev17.il" "deargds") ,then execute downrev17, the skill will ouput all need file to a directory
    then, you can load the skill in 16.6 software,  and excute it, it will create a same file in 16.6 version.
  • jc teyssier
    0 jc teyssier over 2 years ago in reply to tennywhy
    Be aware that some behavior change between 16.x and 17.x (example: dynamic shape: different result)
    And some notion exist in 17.x and NOT in 16.x (example: in 17.2 you can change shape connections to pins per layers; not in 16.6).
    Same for stackup, constraint manager, ...
    I doubt you can get exactly the same thing in 16.x from 17.x. Except for very simple board with no new 17.x feature used and transfers with clipdrawings.
