  3. Removing a View In Draft Center
  • State Verified Answer
  • Subscribers 159
  • Views 6894
gazza47
gazza47 over 2 years ago
I'm working on a Design used Cadence 17.4 and have an issue with the outputs which I'm hoping someone can assist me with.
On the Previous revision of the boards there were Buried via from Layers 3 to 8, these have been removed. However the vias still appear in the stackup and when I attempt to generate the ouputs for the drill files it is still listed as a sheet (although there are only 4 sheets generated). I can also see the layer in the standard Views, however it's not in the selected view. How can I remove this?
Any suggestions appreciated
  • gazza47
    +1 gazza47 over 2 years ago
    I think I've found the answer, it looks like the original designer did not remove all the Buried vias. Updating the design and will check again
