  3. Allegro - Tip of the week: Quick way to get the etch length...
  • Subscribers 159
  • Views 1300
Allegro - Tip of the week: Quick way to get the etch length between two pins of a net having multiple pins
mahimag
mahimag over 2 years ago
Users often want to see the etch length between two pins of a net having multiple pins. A quick way to get this by using the Measure command.
Steps to follow:
  1. Go to the menu Display > Measure.
  2. Enable ‘Pins’ in the Find Filter and select the pins of interest between which you want to see the etch length.
The Etch Distance value will appear when the two pins are connected to each other by clines. Keep in mind that shapes will prevent the calculation.
Hope you found this useful. What are the other ways through which you get the pin pair etch length?
  • avant
    avant over 2 years ago
    Wow! Thanks!
