  3. Problem with OBLONG_Y figure name while using make_axlP...
  • State Suggested Answer
  • Answers 1
  • Subscribers 19
  • Views 2985
Problem with OBLONG_Y figure name while using make_axlPadStackDrill
piorog
piorog over 2 years ago
I would like to prepare padstack drill with OBLONG_Y figure. Everything works correctly except that I get OBLONG_X figure instead of OBLONG_Y. Looks like I always get OBLONG_X whether I type OBLONG_X or OBLONG_Y. There are no issues with other figure names. Is it a bug or I do something in a wrong way?
Here is a line of code responsible for preparing padstack drill:
drill = make_axlPadStackDrill(?usage "Through_pin", ?holeType 'CIRCLE_DRILL, ?plating 'PLATED, ?drillDiameter holeDia, ?figure 'OBLONG_Y, ?figureSize holeDia:holeDia, ?drillChar "AA")
Thank you in advance for your help!
  • mahimag
    0 mahimag over 2 years ago
    Hi, which version of the software are you facing this issue? I tried with latest hotfix of SPB 17.4 (s036) and 22.1(s004) and I can generate OBLONG_X and OBLONG_Y successfully using the parameters you shared in the SKILL API.
  • piorog
    0 piorog over 2 years ago in reply to mahimag
    I use version 17.4 (s021). Here is my result even though I have hardcoded OBLONG_Y figure in my script:
    It seems like it's caused by equal drill figure width and drill figure height.
    This gives me OBLONG_X:
    drill = make_axlPadStackDrill(?usage "Through_pin", ?holeType 'CIRCLE_DRILL, ?plating 'PLATED, ?drillDiameter 500, ?figure 'OBLONG_Y, ?figureSize 500:500, ?drillChar 'AA)
    while this works correctly with OBLONG_Y:
    drill = make_axlPadStackDrill(?usage "Through_pin", ?holeType 'CIRCLE_DRILL, ?plating 'PLATED, ?drillDiameter 500, ?figure 'OBLONG_Y, ?figureSize 500:800, ?drillChar 'AA)
    I solved the problem by editting the padstack after it is created:
    axlPadstackEdit(Padstack 'drillFigureName 'OBLONG_Y)
  • mahimag
    0 mahimag over 2 years ago in reply to piorog
    Hello, this has been reported to Cadence R&D via Cadence Change Request 2817366
    Mahima
