  3. Create Thru Pin with BEGIN LAYER/END LAYER names using ...
  • State Verified Answer
  • Subscribers 20
  • Views 3254
Create Thru Pin with BEGIN LAYER/END LAYER names using SKILL
piorog
piorog over 2 years ago
I am trying to make a Thru Pin using SKILL. The problem that I encountered is that Thru Pins made manually in Padstack Editor have these layers' names:
while, when I am making them automatically via script, I am only able to put there TOP and BOTTOM instead of BEGIN LAYER and END LAYER:
I would like to keep padstacks made manually and via script consistent, but I can't because I get such warnings:
*WARNING* (axlDBCreatePadStack): No match for subclass name - "PIN/END_LAYER"
*WARNING* (axlDBCreatePadStack): No match for subclass name - "PIN/BEGIN_LAYER"
Is there any way to use make_axlPadstackPad function with layers' names corresponding to how they are set in Padstack Editor?
If not, do padstacks prepared in two different ways (with different layers' names) could cause any issues while using them on the same board?
  • revida marcos
    0 revida marcos over 2 years ago
    In contrast to the Padstack Editor, it appears that utilising the "make_axlPadstackPad" function in SKILL does not directly enable the usage of "BEGIN LAYER" and "END LAYER" names for Thru Pins. As an alternative, you may merely define the "TOP" and "BOTTOM" layers.
    When used on the same board, padstacks with various layer names could result in problems. During the production or design verification procedures, it could result in irregularities or unanticipated behaviour.
    You may need to consider different strategies to preserve consistency between manually made padstacks and script-generated ones. The script might be changed, if feasible, to allow for the usage of "BEGIN LAYER" and "END LAYER" names. An alternative would be to utilise "TOP" and "BOTTOM" on the manual padstacks.
  • piorog
    0 piorog over 2 years ago in reply to revida marcos
    Thank you for response!
    I hope there is any workaround to force script-generated padstacks to use BEGIN LAYER and END LAYER naming. Unfortunately, I can't change the manually made ones, as over the years we already prepared more than thousand of them in this way.
  • piorog
    Does anyone have any idea how to solve the issue? I have even tried loading manually created padstack, but SKILL changes layers' names anyway...
  • mahimag
    +1 mahimag over 2 years ago in reply to revida marcos
    Hello revida marcos, If you define a padstack from padstack editor where the design layer names comes as "BEGIN Layer" and "END Layer". Now once you placed a symbol having this padstack in board and you invoke padstack editor from the brd file, it will show the Layer Name same as your cross-section stackup layer name. So there will be no discepency after the symbols/pads are used in board.
