  3. How retain clines signal net name on ground copper pour...
  • State Verified Answer
  • Subscribers 160
  • Views 2223
How retain clines signal net name on ground copper pour area in "Allegro PCB editor 17.4 tool"
Raamvishnuraja
Raamvishnuraja over 2 years ago
Hi, on top layer I have routed clines for "signals" with "ground copper pour" filled, And i dont want the signal clines net name to change automatically by itself to ground net name when i delet by "cline segs" of a "signal clines". just I need to retain the net name for leftover "clines", pleaese let me know the option so it will be help full for swaping the net names without deleting the existing routed clines. FYI I am using "OrCAD PCB Designer Professional 17.4"
refer image below fo reference:
Thanks and Regards
Raam
  • VVRD
    0 VVRD over 2 years ago
    Hello Raam,
    Please check if  "Replace Conductor" option is disabled in  Set up -> Design Parameters -> Route. If it is disabled, enable it and verify whether it's still taking shape net name.
    Thank you.
  • avant
    0 avant over 2 years ago
    A stand-alone cline will not retain a net name.
    I suggest moving the ground plane out of the region you are working on so the cline does not inherit the plane's net name.
  • DBTCH
    +1 DBTCH over 2 years ago
    Hi Raam ,
    To avoid this kind of issue I add the VOID_SAME_NET property to Cline before cutting .
    Regards
