  3. How to create own user -defined Menu in cadence allegro...
  • State Suggested Answer
  • Answers 1
  • Subscribers 162
  • Views 2123
How to create own user -defined Menu in cadence allegro (PCB Editor) ?
kabalee
kabalee over 2 years ago
Hi Everyone,
I need to add own user defined Menu in PCB Editor in 17.X version. i need to add Placement and Routing Menu after Tools Menu. can you  any help , How to map ?
Under Placement i need add Align symbol to pin
Routing Menu --> Xnet Creation
Those thing i need to create. can you suggest.
  • steve
    0 steve over 2 years ago
    Yes - look at the parallel systems website. Choose Guides then look at guide PCB27. This talks about using skill to add a new menu with your entries / skill files.
  • Robert Finley
    0 Robert Finley over 2 years ago
    There is a RAK kit on CDNs support website:  "Adding and Appending Allegro Menu Items Through SKILL"
  • kabalee
    0 kabalee over 2 years ago in reply to Robert Finley
    Hi can you share the link
  • masamasa
    0 masamasa over 2 years ago
    i hope this one helps.
    the link below explains how to customize your menu.
    community.cadence.com/.../make-menus-your-own-customizing-menus-and-toolbars-with-things-you-use-daily
