  3. Creating Group with SKILL
  • State Suggested Answer
  • Answers 1
  • Subscribers 20
  • Views 3164
Tolo1996
Tolo1996 over 2 years ago
Hi Guys,
I have following problem, i wrote script that draw stack up on cross section for multi stack design, (build in stack up cannot do this) here is screen:
So it is draw on manufacturing/stack_up layer and it consist of lines and text,
So i want to group this elements in order to easy change the position of this stackup.
My idea was following
1. Set off all layers:
Display = axlVisibleGet()
axlVisibleDesign(nil)
2. Set on only "MANUFACTURING/STACK_UP"
stack_layer="MANUFACTURING/STACK_UP"
axlVisibleLayer(stack_layer t)
3. Refreh and select all "TEXT" and "LINES" instances
axlDBRefreshId(axlDBGetDesign()) ; refresh the dbid
axlSetFindFilter(?enabled '(noall lines text) ?onButtons '(noall lines text))
groupMembers = axlGetSelSet(axlAddSelectAll())
Now my first attepmt was to use commands
axlDBCreateGroup()
But my problem was a cannot set it up is such way that it will be overwrite te group, so after one run it's crash due to fact that this group already exist
So i use Shell command after i select object using previeusly posted code as follow:
axlShell("group add ")
axlShell("setwindow form.groups_create")
axlShell("FORM groups_create name Stackup" )
axlShell("FORM groups_create overwrite YES" )
axlShell("FORM groups_create done")
axlClearSelSet()
And i got error:
No valid items selected for the current operation, exiting.
So my question is what i need to select to create group or how to create and overwrite existing group using skill comand?
  • B Bruekers
    0 B Bruekers over 2 years ago
    I would suggest to create a format symbol. Create a symbol definition with a unique name for such stackup. Then draw all elements with the symbol definition as parent.  Once everything is added then simply place the symbol at the desired location.
    The main benefit of this is that you can find and delete the symbol(def) with a simple command. Also It is much easier/faster to reposition the symbol than a group of elements.
    So something like this:
    symName = "my_stackup"
    ;delete previous / existing symbol(def)
    when(dbID = car(setof(item axlDBGetDesign()->symdefs upperCase(item->name)== symName))
        axlMsgPut("Deleting previous symbol")
        axlDBCloak('axlDeleteObject(dbID->instances) '(ignoreFixed))
        axlDeleteObject(dbID)
        axlDBRefreshId(nil)    ;after axlDeleteObject() need to update db otherwise axlDBCreateSymDefSkeleton can fail
    drawLayer = "MANUFACTURING/STACK_UP"
    bbox = list(100:100 100:100)    ; could optimize this value so it is only a bit larger than the maximum required bbox. This prevents issues during placement of the symbol.
    if(symdef = axlDBCreateSymDefSkeleton( list(symName "format") bbox)
    then
        ; use several axlDBCreate functions to add elements to the parent 'symdef'.
        ; so create the stackup view here
        axlDBCreateShape(path nil drawLayer nil symdef)
        axlDBCreatePath(path drawLayer 'line symdef)
        axlDBAddProp(symdef list("COMMENT" "what ever you want to add as comment"))
        if(symId = axlDBCreateSymbol(list(symName "format") 0:0 nil 0.0)
        then
            axlMsgPut("Stackup symbol placed" )
            axlDBAddProp(symId list("LOCKED" t))    ;lock it so cannot be accedently edited. (different than fixed)
        else
            axlMsgPut( '("Unable to place symbol %s at 0:0" 3) symName )
        axlDBRefreshId(axlDBGetDesign()) ; update the db so the symbol is already 'visible' during this skill
    else
        axlMsgPut( '("Unable to create symbol definition %s" 3) symName )
