  3. Allegro – Tip of the week: Looking for tighter coupling...
  • Subscribers 160
  • Views 7332
Allegro – Tip of the week: Looking for tighter coupling of differential traces at gathering location
aniju
aniju over 2 years ago
While routing differential pairs, there is always an issue at round pins or vias. Users often want to have a better coupling between the traces by reducing the uncoupled distance.
There is a variable, padentry_factor, which you can use for this purpose. This variable helps specify a percentage value to control gathering for traces exiting a round pin or via while concurrently routing more than one net, such as a differential pair.
The purpose is to let traces gather sooner. The value is used as a percentage to reduce the minimum clearance that the gathering code requires between the pin/via and the second segment of the cline exiting the pad. By default, it requires 100 percent of the applicable minimum segment to pin/via spacing constraint. A value of 75 causes the minimum space to be 75 percent of the constraint set value.
The value for this variable can be set from Setup > User Preferences > Route > Connect.
Hope you found this useful. What are the other ways you follow to get a better coupling of differential pairs with longer lengths?
  • masamasa
    masamasa over 2 years ago
    this is a cool feature but the 10 percent of which dimension in the "padentry_factor set to 10" figure?
  • geda
    geda over 2 years ago in reply to masamasa
    If the minimum segment to pin/via spacing constraint is set to 10mil, then with the "padentry_factor" set to 10, tool considers the minimum segment to pin/via spacing constraint to 10% of 10mil which is 1mil at pad entry.
  • JITHINDEV
    JITHINDEV over 2 years ago
    Does this kind of pad entry result in acute angle DRC?
  • geda
    geda over 2 years ago in reply to JITHINDEV
    There are chances that this can result in acute angles, based on the value you set for padentry_factor. The Acute Angle Detection DRC check can be used to catch any such acute angles.
