  3. Comparing floating point numbers
  • Subscribers 163
  • Views 15603
archive over 20 years ago
Unexpected results can occur when checking two floating point numbers for equality.
For example:
a = 0.1
b = 0.3 / 3
a == b returns nil.
This behaviour is due to the IEEE floating point implementation and is explained well in: http://sourcelink.cadence.com/docs/db/kdb/2004/Dec/11162336.html
You can use the following function to test for equality of two floating point numbers:
defun( feq (f1, f2), abs(f1 - f2)
Cheers Dave.
Originally posted in cdnusers.org by Dave Elder
    In Allegro you can use axlGeoEqual(a b)
    Originally posted in cdnusers.org by fxf
