  2. PSpice
  3. There are no data values in section number 1 Ignoring this...
  • Replies 8
  • Subscribers 32
  • Views 8432
There are no data values in section number 1 Ignoring this section
HC20250310444
HC20250310444 over 1 year ago
I downloaded three simulation models of MOS transistors from the official website of Infineon and imported them into my pspice simulation. When I run the simulation, this prompt box pops up: There are no data values in section number 1 Ignoring this section.
After clicking OK, another prompt box pops up saying My simulation dat. File analysis failed.
After turning off the prompt box, I noticed that the calculation process and output window still displayed these few errors:
ERROR(ORPSIM-16551): Floating point computation failed during Device/Model Load Possible solutions: 1)Ensure that all device parameters are in valid range. 2) Try using option LIMIT .
INTERNAL ERROR--Overflow in device X_U2.X1.G_chan. Multiply.
At present, I have tried to adjust the limit to 1E-12, or turn on automatic convergence, or connect a small resistor in series between the G and S terminals of the MOS transistor, but none of them have been able to solve the problem. I want to ask for help. How should I solve this simulation problem now?
  • HC20250310444
    0 HC20250310444 over 1 year ago in reply to AyushD
    Hi Ayush,
    my outlook mail number is c7649246699. You can send mail to this addres, and then I will upload my zipped project to you.
    Thanks.
  • AyushD
    0 AyushD over 1 year ago in reply to HC20250310444
    Check your mailbox, it should be there.
  • HC20250310444
    Hi. My design file has been attached.
