  2. PSpice
  3. There is something wrong with my device model, which always...
  • State Suggested Answer
  • Answers 1
  • Subscribers 26
  • Views 4592
There is something wrong with my device model, which always leads to mistakes in simulation, but I don't know where the mistakes are.
JQ202504092110
JQ202504092110 8 months ago
This is my PSPICE model:
.SUBCKT MEMRISTOR 1 2
Cx 3 0 1e-9 IC=0.314
Rx 3 0 1G
Vstp TIME 0 PULSE(0 1 0 1ns 1ns 1s 2s)
E_stp 4 0 VALUE { IF(TIME > 0, 0, 1) }
B_fx 5 0 V=1 - ( (0.9 * (V(3) - V(4)) ** 2 + 0.1) ) ** 10
Gx 0 3 VALUE { 1e-14 * 100 / (10e-9)**2 * I(Vsense) * V(5) }
E_Rmem 6 0 VALUE { 16e3 - V(3) * (16e3 - 100) }
Rmem 6 7 1
Vsense 1 7 DC 0
Rout 2 7 1e-12
.ENDS MEMRISTOR
This error occurred during my simulation:But I don't know what's wrong. Please help me analyze it.
ERROR(ORPSIM-16152): Invalid number: Error while converting token '-' to double value. Token can be a constant or expression
  • rg13
    0 rg13 8 months ago
    It seems there is some syntax error in library which you are using. Could you share your archived project along with Pspice library (.lib) to Cadence ASK team?
  • oldmouldy
    0 oldmouldy 8 months ago
    You have a B device for "B_fx" which is SPICE 3 and PSpice is SPICE 2. Since this B device is generating a Voltage, you can use an Evalue, like the other E devices, to replace the B device.
  • JQ202504092110
    0 JQ202504092110 8 months ago in reply to oldmouldy
    When I changed B_fx to E, there was a new error:
  • JQ202504092110
    0 JQ202504092110 8 months ago in reply to rg13
    I don't know how to upload lib files,The following is my lib file code
    .SUBCKT MEMRISTOR1 Plus Minus PARAMS: Roff=16k Ron=100 D=10n uv=1e-14 p=10
    Cx x 0 1p IC=0.314
    E_stp stp 0 VALUE { IF(TIME >= 0, 1, 0) }
    E_arg arg 0 VALUE { 0.9*(V(x)-V(stp))**2 + 0.1 }
    E_f f 0 VALUE { 1 - (V(arg)**10) }
    Gdx 0 x VALUE { V(Plus,Minus)/(Roff - V(x)*(Roff-Ron)) * V(f) * 1e6 }
    Rmem Plus Minus R={Roff - V(x)*(Roff-Ron)}
    .ENDS MEMRISTOR1
  • JQ202504092110
    0 JQ202504092110 8 months ago in reply to JQ202504092110
    Does this also need to be defined by value?
