  2. PSpice
  3. PSpice for TI installer fails: HTTP 403 Forbidden downloading...
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 35
  • Views 1512
PSpice for TI installer fails: HTTP 403 Forbidden downloading TI_URLs.txt
ZS202610299347
ZS202610299347 23 days ago
Hello Cadence Support,
I am unable to install PSpice for TI because the installer cannot download its configuration file.
Installer message:
"Unable to access the URL required for installation"
Failing URL:
pcb.cadence.com/.../TI_URLs.txt
The same URL returns HTTP 403 Forbidden when accessed directly outside the installer.
Observed response details:
- Server: CloudFront
- X-Cache: Error from cloudfront
- HTTP status: 403 Forbidden
The installer’s network check reports that Internet connectivity and TLS 1.2 are available, and that proxy credentials are not required. The problem has been reproduced repeatedly.
Could you please confirm whether access to this object has been intentionally restricted or misconfigured, and either restore access or provide the current official installation procedure / replacement endpoint for PSpice for TI?
I can provide the installer log (cdsPspiceTIlog.txt) if needed.
Thank you.
  • rg13
    rg13 6 days ago +1 suggested
    Due to oncloud server outage, currently this is not working. Concerned team is working on it. Once it is fixed, will update you.
  • MH202611184059
    0 MH202611184059 3 days ago
    I do experience the same problem
    Can it be the servers are really down for that long?
    This is my log file after experiencing the problem:
    09:18:43 Mittwoch, 18. November 2026 : parameter count = 1
    09:18:43 Mittwoch, 18. November 2026 : -wrapper
    09:18:43 Mittwoch, 18. November 2026 : Module Name: TIPSpice.exe
    09:18:43 Mittwoch, 18. November 2026 : Server OS = False
    09:18:43 Mittwoch, 18. November 2026 : Operating system version : 10.0.0.0
    09:18:43 Mittwoch, 18. November 2026 : Checking for proxy
    09:18:43 Mittwoch, 18. November 2026 : Der Remoteserver hat einen Fehler zurückgegeben: (403) Unzulässig.
    09:18:43 Mittwoch, 18. November 2026 : Response error : Forbidden
    09:18:43 Mittwoch, 18. November 2026 : Checking if Licensing URL is accessible
    09:18:44 Mittwoch, 18. November 2026 : Initializing
    09:18:44 Mittwoch, 18. November 2026 : Downloading URLs file from : pcb.cadence.com/.../TI_URLs.txt
    09:18:44 Mittwoch, 18. November 2026 : Exception occured while downloading file : pcb.cadence.com/.../TI_URLs.txt
    09:18:44 Mittwoch, 18. November 2026 : Der Remoteserver hat einen Fehler zurückgegeben: (403) Unzulässig.
    09:18:44 Mittwoch, 18. November 2026 : Response error : Forbidden
    09:18:44 Mittwoch, 18. November 2026 : Response Description: Forbidden
    09:18:44 Mittwoch, 18. November 2026 : C:\Users\hopfm\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 0
    09:18:44 Mittwoch, 18. November 2026 : Error occured while downloading URL file
    09:18:44 Mittwoch, 18. November 2026 : Error Message: Der Remoteserver hat einen Fehler zurückgegeben: (403) Unzulässig.
    09:18:44 Mittwoch, 18. November 2026 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
    URL: pcb.cadence.com/.../TI_URLs.txt
    Error code: Forbidden
    Error Description: Forbidden
    View log file for details at C:\Users\hopfm\AppData\Roaming\Cadence\PspiceTIInstall\cdsPspiceTIlog.txt
  • JG20261118178
    0 JG20261118178 3 days ago in reply to rg13
    I've had the same problem when trying to install PSpice for TI.
