  2. Design Entry HDL
  3. Design Entry HDL
  • Subscribers 25
  • Views 17429
Design Entry HDL
anucheruvx
anucheruvx over 6 years ago
In the design entry hdl schematic, I'm not able to edit page name. Edit  page name is disabled.Please help to resolve this.
  • CadAce2K
    0 CadAce2K over 6 years ago
    You may need to go in the SCH folder and check on the properties of the .csa and .csb page files. They might be write protected. Often times I've had to removed the extra files (e.g. .csp for example, if I remember correctly) and re-read them back in before I could write them again. I'm guessing it's a permissions issue.
  • anucheruvx
    0 anucheruvx over 6 years ago in reply to CadAce2K
    Thank you your reply. I checked the write permission. But it was not the reason .In order to enable edit page name, go to Tools-> Options, take Design Navigation, take "Property on page border for page name" and give  PAGE_TITLE in the box given and then the issue got solved.
  • Thebrakshow
    0 Thebrakshow over 6 years ago
    Click on File -> Save Hierarchy then try to change the page names as you were doing.
    • Vote Up -1 Vote Down
  • tmd63
    0 tmd63 over 4 years ago in reply to Thebrakshow
    That didn't work for me.
  • tmd63
    0 tmd63 over 4 years ago in reply to anucheruvx
    Tools->Options. Click 'Design Navigation' and enter 'PAGE_TITLE' in the box under 'Property on page border for page name'. Then apply and 'save hierarchy'.
    Just to clarify the steps that worked.
