  2. Design Entry HDL
  3. global component change problem
  • Subscribers 23
  • Views 11456
myil17
myil17 over 3 years ago
I am having the following errors. Why is this happening? Have any ideas to solve the problem? I can't select the offline library manually on new component option. Is there an option to give libraries(offline and database) a priority for this task?
  • rg13
    0 rg13 over 3 years ago
    Looking at the error, it seems that component mentioned under original and new component are not present at their location. See if gnd_signal is present in standard library and agnd is present in design_lib library.
    Also you can check whether the paths are correctly mentioned in cds.lib or not.
  • srish09
    0 srish09 over 3 years ago
    Looks like these components are missing from your reference library. Are you working in EDM environment? And these components are not part of the EDM reflib but referenced locally? If this is the case try switching to Offline mode in Part Information Manager (File > Switch to Offline) and perform global update.
  • myil17
    0 myil17 over 3 years ago in reply to rg13
    They are both present in the library. There are two kind of libraries; offline(both gnd components exist under this library) and database which is used and updated by the company. The problem is when i click ''global component change'' and select "original component", I can access the offline library which is perfect but when I choose the "new component", i can only access the database library. I would like to access only offline library for both cases. But it complains that the component doesn't exist.
  • myil17
    0 myil17 over 3 years ago in reply to srish09
    Yes, I am working in EDM environment. I feel like offline library and database(which is used and updated by the company) library somehow conflict. I tried to change it to offline from part information manager but nothing has changed. From component to change selection, only offline library is available and from new component selection, only database library is available and i don't know why it's like that.
