  2. Design Entry HDL
  3. pxl failed error
  • Subscribers 23
  • Views 9446
pxl failed error
myil17
myil17 over 3 years ago
Why am i receiving this error? Is there a way to solve it?
  • srish09
    0 srish09 over 3 years ago
    The screenshot does not have much information. Check for the detailed error message in the pxl.log file. That might give some idea on what could be going wrong.
  • myil17
    0 myil17 over 3 years ago
    Thank you for your reply. I found solution to this: Right click + Modify + Select the component + OK. I had more errors due to the use of same refdes. I changed all the refdes that has the same name.  here is the article that corresponds to that problem.
    support.cadence.com/.../cos
