  2. Design Entry HDL
  3. Error while saving schematic while testing - DE-HDL
  • Subscribers 23
  • Views 3490
pareshcdac
pareshcdac over 3 years ago
Getting the following error while trying to save a schematic in DE-HDL. I'm trying to create my own part. So, when manually testing it in DE-HDL. I'm getting this error. I've attached properties screenshots for reference.
ERROR(SPCOCN-1993): The value specified for the property 'PACK_TYPE' is invalid. The value '?' can be specified only for soft properties that have '$' as a prefix in the property name. Either prefix '$' to the property name or specify a valid value for user defined properties, and save the schematic again. (placeholderprops)
I'm following the cadence PCB Librarian tutorials, and have made changes according to that
Any input would be useful.
Properties under Symbol
Setup
  • rg13
    0 rg13 over 3 years ago
    You can refer below link of an article which I found on Cadence Online support portal:
    Article (20497627) Title: ERROR(SPCOCN-1993) on saving the schematic page in Allegro Design Entry HDL
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AHGaqEAH
    This article describes, in which scenario user gets this error and how to get rid of this error.
  • pareshcdac
    0 pareshcdac over 3 years ago in reply to rg13
    Okay, thanks. Will try it out
