  2. Design Entry HDL
  3. Syntax error while trying to export OrCAD schematic to PCB...
  • Subscribers 24
  • Views 9553
Syntax error while trying to export OrCAD schematic to PCB editor
blackhawk2611
blackhawk2611 over 3 years ago
I am getting the following error while trying to export my schematic to PCB editor.:
#1 ERROR(7) Syntax error : string not closed
End of line inside string in lines 2934-2935
How can this be fixed?
  • atishcdns
    0 atishcdns over 3 years ago
    You may have a "carriage return" character in one or more of the PCB Footprint properties in the component instances or component definitions in your Capture design.
    If you are using the earlier build of Capture you will need to examine the lines of the pstchip.dat file that the error 7 is reporting as suspect. You will see something like:
        JEDEC_TYPE='somefootprintname
    The corrected entry should read:
        JEDEC_TYPE='somefootprintname';
  • blackhawk2611
    0 blackhawk2611 over 2 years ago in reply to atishcdns
    How can I save the changes after editing the entry? When I reopen the file, I find that the changes have not been saved.
