  2. Design Entry HDL
  3. Display all components pins label
  • State Verified Answer
  • Subscribers 23
  • Views 7776
SonN
SonN over 2 years ago
Hi -
How can I turn ON all components pins label for all pages from the schematic?
I know how to manually right click => Section => Section.
Son
  • rg13
    +1 rg13 over 2 years ago
    If we apply Backannotation option (Backannotate packaging properties) at the time of Export physical, that also brings pin text as a label of pin on DEHDL schematic.
    You may also want to refer following article link which I found on Cadence online support portal:
    Article (11573720) Title: How do I make the pin numbers visible when a part is added in the schematic?
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nYx6EAE
  • SonN
    0 SonN over 2 years ago in reply to rg13
    Thanks, rg13 for your responding.
    I've tried to select and un-check the "backanotate", and then run "export physical" but the component pins still did not display like Resistor pin-1 and pin-2.
    Do you mind I have another question here that I do not want to re-use the component ref des. For example, I have R5. I delete R5 on circuit-1. Then I add another resistor on the circuit-2. I un-check reuse ref des number, and then run "export physical"; however, R5 assigned on the new resistor of circuit-2.
