  2. Design Entry HDL
  3. How to connect two different nets together but preserve...
  • State Suggested Answer
  • Answers 1
  • Subscribers 24
  • Views 8457
How to connect two different nets together but preserve different names?
DenzilPenberthy
DenzilPenberthy over 2 years ago
HI,
I have I have a current sense shunt resistor. It has high current passing through it  and needs two sense lines to create a 4 point kelvin connection.
The high current and the assosciated sense lines are electrically the same net (e.g. VCC) but physically I want to route the sense line separate from the VCC power plane. So I want a net called for example VCC_SENSE. How do I connect these to my resistor without generating a DRC that two different nets are connected together?
Cheers.
  • jc teyssier
    0 jc teyssier over 2 years ago
    can be done with a component with 2 copper pins on required layer. Pin may overlap in component. Create also a constraint region at the overlapping location. region should include both pad orign.
    In brd, assign to this region a spacing constraint set with smd_pin to smd_pin set to -1
    -1 value means "no check"
    • Vote Up +2 Vote Down
  • DenzilPenberthy
    0 DenzilPenberthy over 2 years ago in reply to jc teyssier
    Thanks, this -1 means no check thing is a very useful tip.
