  2. Design Entry HDL
  3. Adding Attributes to Multiple Components
  • State Suggested Answer
  • Answers 1
  • Subscribers 23
  • Views 7046
gazza47
gazza47 over 2 years ago
Can anyone advise on the following issue, I'm using Cadence 17.4 Design Entry
We have a Schematic in which there are a number of Test Points and we wish to add the Attribute BOM_IGNORE to all these Components so when we create a Bill of Materials these components are not included.
Is there a way in which we can add the Attribute Globally to all Test Pads rather than add the attribute individually to each Component
Any assistance appreciated
  • rg13
    0 rg13 over 2 years ago
    Found the following article on Cadence online support portal:
    Article (20497186) Title: How to add a global attribute/property to all components in a design using a script in DE-HDL
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AHAt9EAH
    There is one script attached to this article. Where, it tries to add certain property to all components present in the design. To find all components, it applied find $location. However, as you mentioned, you want this property to be applied to test points. Lets say test points has Reference prefix as TP then you can replace script line as, find $location=TP*
