  3. SysCap - Tip of the Week: Wiring made easy
  • Subscribers 32
  • Views 2850
DesignTech
DesignTech over 4 years ago
When you have large pin count components, drawing individual wires is repetitive and time consuming. You can now use the Draw Stub feature to automatically draw the wires. Select a component, right-click, and select Draw Stub. The nets created can have net names with set prefixes/suffixes or pin names. System-generated net names can also be created using this feature.
Place the two component pins one over the other and drag them apart to draw wiring connections.
Drop a discrete between any of the connected wires to form a connection.
Team DesignTech
Cadence Design Systems
  • krunker
    krunker over 4 years ago
    It's really helpful for me. Thank for your sharing.
    krunker
