  3. SysCap - Tip of the Week: Net naming and renaming
  • Subscribers 29
  • Views 3872
DesignTech
DesignTech over 4 years ago
System Capture has an innovative way of naming and renaming signals that can save hours of your time.
Select a wire to name it in the docked property window. Existing signals in the design are displayed while you start typing the signal name.
You can rename multiple nets simultaneously using the tabular format option. Select multiple signals, right-click and select Rename to get the Rename signals window. Signal names from an external file can also be copy-pasted directly.
Team DesignTech
Cadence Design Systems
