  3. Why to use Allegro System Capture – Customize Options
  • Subscribers 26
  • Views 8878
DesignTech
DesignTech over 3 years ago
You can control the look and feel of System Capture, for example, the page border that you use in the project, the way grids or signal names are displayed, the System Capture theme, keyboard shortcuts, and so on.
You can access the customization options in System Capture by using Edit > Preferences.
The System Capture theme can be controlled in the General option.
Using the Project Explorer option, you can select the items that you want to see in the Project Explorer view.
In Schematic > General settings, you can control settings like Repetitive paste, Display value for newly added attributes, Output folder, and so on.
Go to Edit > Preference to explore many more customization options.
For detailed information, refer to chapter 5, Customizing System Capture Settings of the Allegro System Capture User Guide.
Team DesignTech
Cadence Design Systems
