  3. SysCap - Tip of the Week: Bus Connection
  • Subscribers 30
  • Views 2913
DesignTech
DesignTech over 4 years ago
Drawing bus connections is now easy. Gone are the days when you had to select the bus tap symbols manually.
Draw a bus, assign a bus name, select the required wire stubs, and drag and drop them on the bus. Specify the bus bit range and the bus connection is done.
Signal names are assigned based on the bus name and the specified bit range.
Team DesignTech
Cadence Design Systems
