  3. Orcad library files with file names with spaces are not...
  • Subscribers 27
  • Views 8783
Orcad library files with file names with spaces are not supported in Allegro system capture
Zhifeng Jin
Zhifeng Jin over 3 years ago
Hello!cadence experts:
      When I add an OLB library file with a space file name in Allegro system capture, Allegro system capture can normally display the symbols in the library,
but when it is added to the schematic diagram, it will prompt: "CGCAN-861: Symbol bead:bead not found in library'capture library'.Run Part Manager and update this part."
  • atishcdns
    0 atishcdns over 3 years ago
    As per my understanding, design and library paths should not contain spaces
  • Zhifeng Jin
    0 Zhifeng Jin over 3 years ago in reply to atishcdns
    A very common thing is that Orcad and Allegro can support it. Why is it not supported when you enter system captureJoy
