  3. Why to use Allegro System Capture – Extended Nets (XNets...
  • Subscribers 25
  • Views 9466
Why to use Allegro System Capture – Extended Nets (XNets)
DesignTech
DesignTech over 3 years ago
An eXtended Net (XNet) is a connection between two nets that are usually connected through a passive or discrete component like a resistor or capacitor.
XNets are significantly used while defining board-level constraints. Constraint Manager interprets the individual net segments as a single continuous XNet.
Extended net XNet
In System Capture, you can create XNets in the following ways:
Automatic XNet creation
  • XNets are created between pins of a discrete device automatically.
  • Additionally, to create XNets between pins of a non-discrete device, you can use the XNET_PINS property on component pins.
Manual XNet creation
XNets are generated when the XNET_PINS property is defined on component pins at instance level or library level.
Creation of XNets is controlled by the auto_xnets_using_gates directive defined in the CANVAS section of the project or site cpm file.
By default, the auto_xnets_using_gates directive is set to ON, meaning that XNets are created automatically. For manual creation, this directive is set to OFF.
XNet CPM Directive
Team DesignTech
Cadence Design Systems
