  3. How to Setup Sytem Capture with DE-HDL Librarys to Suport...
  • Subscribers 27
  • Views 7397
How to Setup Sytem Capture with DE-HDL Librarys to Suport Multi Customers
PIPE
PIPE over 3 years ago
Hello All,
This is my first post here, so i hope you can help me do answer my question or ou point me do a other place to ask.
I use system capture with DE-HDL Librarys only.
I worked with differnt customer which have all his own librarys.
I the past as i worked with concept this was a easy task to do this.
I have a folder system for every customer and on this folder i have allways a pcbenv, cdssetup, librar and project subfolder etc...
I can config this easy with the home and CDS_SITE Setting.
In the enviroment i change the settings bevor i start do work to my customer.
Start the projectmanger and all is done.
How can i make this working with the new system Capture and pulse configuration.
Peter
  • atishcdns
    0 atishcdns over 3 years ago
    Hi You can try to create multiple CDS_SITE for different customers as you do for DE-HDL. You can also create a batch file and set the environment variables for different customers.
    set CDSROOT=C:\cadence\SPB_22.1
    set PATH=%CDSROOT%\tools\pcb\bin;%CDSROOT%\tools\bin;%CDSROOT%\tools\libutil\bin;%CDSROOT%\tools\fet\bin;%CDSROOT%\tools\specctra\bin;%CDSROOT%\tools\pspice;%CDSROOT%\tools\capture;%CDSROOT%\openaccess\bin\win32\opt;%CDSROOT%\tools\pspice\library;
    set CHDL_LIB_INST_DIR=%CDSROOT%
    set CONCEPT_INST_DIR=%CDSROOT%
    set CDS_SITE=C:\SITE1
    set CDS_LIC_FILE=5280@abc
    set OA_PLUGIN_PATH=C:\cadence\SPB_22.1\share\oaPlugIns
    set TEMP=C:\temp
    set TMP=C:\temp
    set HOME=C:\cadence_home
    cmd
    Double click on batch file to open the command prompt, type syscap to invoke System Capture. System Capture will take all SITE setting that you have defined.
    You can refer to Article (20503194) Title: Configuring DE-HDL Libraries and Importing DE-HDL Design to System Capture
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009TJUFEA4
