  3. How to add a physical quantity like current and frequency...
  • Subscribers 26
  • Views 5050
How to add a physical quantity like current and frequency on a wire in Allegro 17.2.
jroak0911
jroak0911 over 2 years ago
I use Allegro System Capture v17.2.
When wiring, is it possible to add the physical quantity like current and frequency on wire with property?
The capture below is a wire which is added current value by a comment.
Is there a better way?
Also, could tell me detail of role of each property name that can be selected in property.
  • srish09
    0 srish09 over 2 years ago
    I tried adding current and frequency on nets and was able to do so. However, I tried this on the latest 22.1 release. Are there any error/warning messages when you add current and freq on wires?
    Regarding details of each property, try searching on Cadence Online Support (https://support.cadence.com/).
