  2. Adams Car
  3. Problem with python code in macro called from Adams/Car...
  • Replies 7
  • Subscribers 1
  • Views 4
Problem with python code in macro called from Adams/Car 2018
1ondrej.petergac
1ondrej.petergac over 6 years ago
I am trying to run python code from the macro in the Adams/Car 2018.
The python code is following:
!--- Run PYTHON code
variable set variable_name=$_self.intTmp integer_value=(eval(run_python_code("import glob, os, os.path")))
variable set variable_name=$_self.intTmp integer_value=(eval(run_python_code("cwd = os.getcwd()")))
variable set variable_name=$_self.intTmp integer_value=(eval(run_python_code("filelist = glob.glob(os.path.join(cwd, 'tmp_*'))")))
variable set variable_name=$_self.intTmp integer_value=(eval(run_python_code("for f in filelist:")))
variable set variable_name=$_self.intTmp integer_value=(eval(run_python_code("   os.remove(f)")))
When the python code is called in Adams/Car 2018 then I get following error message in the log file:
!  File "<string>", line 1
!    for f in filelist:
! SyntaxError: unexpected EOF while parsing
!    os.remove(f)
! IndentationError: unexpected indent
When I run the same python code from DOS shell with command: adams2018 python ***.py then the code runs without any problem.
What could be the problem?
Can a python for loop be started in macro with (eval(run_python_code(…)))?
Thanks and best regards,
Ondrej
  • 1ondrej.petergac
    0 1ondrej.petergac over 6 years ago
    Hello Martin,
    thanks a lot for another hint.
    Best regards,
    Ondrej
  • MK202610123211
    0 MK202610123211 over 6 years ago
    I have to correct myself concerning the good opinion about file python read.
    My new setting is "it sucks".
    Check here for details:
    simcompanion.hexagon.com/.../severe-bug-in-v20192-file-python-read
    In a nutshell: DO NOT USE use file python read. Use run_python_code("exec(open('xxx..py').read())") instead !
