  2. Adams Car
  3. Steer angles are different for same Rack Travel in Suspension...
  • State Verified Answer
  • Replies 7
  • Subscribers 1
  • Views 11
Steer angles are different for same Rack Travel in Suspension analysis and Full vehicle analysis.
dmvachhani
dmvachhani over 4 years ago
Dear all,
Rightnow I am going through one problem and that needs to investigate as soon as possible.
I have optimized the hardpoints to get the desired steer angles for 85mm rack travel at suspension level.
---- Suspension Level Analysis
Now, While I am running steering analysis at suspension level, I am getting following results.
Inner_Wheel_Angle = 42.5deg (Optimized Value)
Outer_Wheel_Angle = 35.6deg
---- Full Vehicle Analysis
Now, when I have used the same suspension in my full vehicle and running Turn Diameter event, I am getting following results with same rack travel.
Inner_Wheel_Angle = 43.5deg
Outer_Wheel_Angle = 35.0deg
Then I have adjusted the rack travel to get Inner_Wheel_Angle = 42.5 deg but then Outer_Wheel_Angle is reduced to 34.2 deg.
So now my confusion is why full vehicle event showing me different steer angles for same rack travel ?
Also, why outer angle is different for same inner angle in full vehicle event compare to suspension level analysis ?
Just to note, I am running the full vehicle event at very slow speed and using PAC tire model but I guess same geometry should give the same result.
It will be very helpful to have your comments on this confusion.
Thank you very much in advance.
Darshan
  • Jesper Slattengren
    0 Jesper Slattengren over 4 years ago
    Hi Darshan, one more thing that affects your results:
    Unless you have perfect Ackerman compensation (100%) in your steering/suspension, then no matter how slow you are driving, the tires will have a slip and will fight each other. In this case one wheel will steer more and the other less than what the suspension testrig predicts.
  • dmvachhani
    0 dmvachhani over 4 years ago
    Yes. It seems all the points you mentioned here have some contribution on the difference between suspension and full-vehicle analysis and its convincible to me now.
    I really thankful to all of you for your help me to understand this issue.
    Thank you very much !!
    Darshan
