  2. Adams Car
  3. Defining Gravity for New Templates in ACAR
  • State Verified Answer
  • Subscribers 1
  • Views 47
James Parkus
James Parkus 11 months ago
Hey folks,
I am trying to understand the finer details of how Adams/Car defines gravity when creating a new template, sub-assembly, and an assembly part. The model I'm working is not Earth Gravity and I've setup an "acarAS.cmd" command file to modify the already-created gravity vector.
This leads me to two questions;
  1. When and where does ACAR create the gravity vector and can I adjust the value there so I don't need to worry about using the "acarAS.cmd" file?
  2. If there are gravity vectors in templates set to Earth gravity, and then those same templates used in an assembly (via sub-assemblies) which has a gravity vector set to a non-Earth gravity (say Mars for example) – which gravity will be used in the simulation of the assembly?
Best,
James
Code for acarAS.cmd file
if cond=((eval(.system_defaults.units_consistency_factor )) == 0.)
default units length=meter mass=kg force=newton time=Second angle=degrees frequency=hz
view manage modify spacing_for_grid=1.0
end
color mod color=.colors.background red_component= 0.16 &
green_component=0.46 &
blue_component= 0.65 &
gradient= "none"
force modify body gravitational gravity = .__ACAR.gravity &
x_comp = 0.0 &
y_comp = 0.0 &
z_comp = (1.35(m/s/s))
  • greg.wheeler
    greg.wheeler 11 months ago +1 verified
    Hi James. As of a few versions back, gravity is now saved in your assembly file, so you no longer need to use an acarAS script: [GRAVITY] X_COMPONENT = 0.0 Y_COMPONENT = 0.0 Z_COMPONENT = -4800.0
  • greg.wheeler
    greg.wheeler 11 months ago in reply to James Parkus +1
    Gravity defined in templates is ignored!
  • James Parkus
    0 James Parkus 11 months ago in reply to Jesper Slattengren
    Thanks Jesper. Greg told me this modification to ACAR (to alleviate the need for the acarAS.cmd) was done in 2023.4.1, so everything including that and afterwards won't need it. Unfortunately, I am stuck with using 2021.0.1 for now so I will retain it until we're allowed to upgrade.
