Home
  • Products
  • Solutions
  • Support
  • Company
This search text may be transcribed, used, stored, or accessed by our third-party service providers per our Cookie Policy and Privacy Policy.
  • Products
  • Solutions
  • Support
  • Company
Community System Analysis Sigrity Tip of the day – Obtaining pin voltage and currents in IR...
  • Subscribers 20
  • Views 3221
Tip of the day – Obtaining pin voltage and currents in IR Drop analysis
SimTech
SimTech over 1 year ago
After IR Drop analysis, it is important to check pin currents and voltages to understand the power integrity performance of the PCB. The tool provides VRM and SINK voltages and currents. Also, if there is an option to print the voltage and current at pin location to a CSV file, it will help you further in postprocessing.
Sigrity PowerDC provides an option to export voltage and current values at pin locations.
You can select the pin current/voltage for VRMs, SINKs, and discrete components. These values will be available in the CSV file.
For example:
This function should help you get the current and voltage at pin locations for further postprocessing.
Share your thoughts on this feature.
Team SimTech
Cadence Design Systems
