  2. Sigrity
  3. Join us for our next Live Experts Session: PowerSI & S-Parameter...
  • Replies 23
  • Subscribers 22
  • Views 2104
Join us for our next Live Experts Session: PowerSI & S-Parameter Analysis on July 29th 2026
Renu Vibha
Renu Vibha 2 months ago
Curious about S-Parameter extraction, Insertion Loss, and Return Loss?
Join us here for a live session with Cadence experts and get answers to your toughest Signal Integrity questions.
Wednesday July 29, 2026 at 8:30 PM – 9:30 PM IST
Topics:
S-Parameter Extraction
Insertion Loss Analysis
Return Loss Analysis
Why Join?
Ask questions live
Learn from real-world use cases
Gain practical SI insights
Connect with peers and industry experts
Don't miss this opportunity to engage directly with the experts and discover proven approaches to your SI challenges.
Bring your questions. Leave with answers.
  • ALLpdf
    ALLpdf 2 months ago in reply to CF202606104231 +3
    Please let me know if it answers your query... or if you have any more questions.
  • ALLpdf
    ALLpdf 2 months ago in reply to ALLpdf +3
    2‑port/3‑terminal device is not appropriate for AMM's 1‑port decap workflow. Its behavior is better represented by transfer terms (Z21/Z12) . Perform Z21/Z12 analysis in PowerSI, which is designed for…
  • ALLpdf
    ALLpdf 2 months ago in reply to CF202606104231 +2
    You can extract the S-Parameters, inductance, capacitance, and resistance of the power and ground nets of a package using the XtractIM " Electrical Performance Assessment " flow.
  • ALLpdf
    0 ALLpdf 2 months ago in reply to CF202606104231
    Thanks for asking the question. You can do it using our XtractIM tool.
  • ALLpdf
    Using Electrical Performance Assessment flow in XtractIM, you users can extract S‑parameters and RLC values for power and ground nets by setting up a Power‑Ground Analysis simulation. The results are available in the Per Net‑Pair Properties panel and as S or Z‑parameter plots.
  • ALLpdf
    You can extract the S-Parameters, inductance, capacitance, and resistance of the power and ground nets of a package using the XtractIM "Electrical Performance Assessment" flow.
    • Vote Up +2 Vote Down
  • ALLpdf
    Follow these steps to generate the S-Parameters, inductance, capacitance, and resistance of power and ground nets:
    1. In XtractIM, switch to the Electrical Performance Assessment workflow and load the design file.
    2. In the Workflow items, go to Simulation Setup > Setup for Power-Ground Analysis.This will open a Simulation Type pane at the bottom.
  • ALLpdf
    0 ALLpdf 2 months ago in reply to ALLpdf
    3.Enable the Inductance, Capacitance, and Resistance and Broadband Impedance (Single Die-Single BGA without Decaps) options.  Go to the Net Manager window and select the desired power and ground nets.
    4.Go to Simulation > Start Simulation ​After the simulation is complete, the tool will display the impedance results in the Broadband Impedance tab.5.
    Along with the broadband impedance results, the tool also displays the inductance, capacitance, and resistance results in the Inductance, Capacitance, and Resistance tab, as shown below.
